Notepad++ Language Template
Is there a language template in the wild for Netlinx? Thanks.
I use Notepad++ as my default text editor and it would be great to get syntax highlighting (and code beatification) running when I FTP into my server to quickly double check a few details on an existing project.
I might have time to start looking into it next month, but that is fairly doubtful.
e.g. This line will show up as comment: (* ******
But this line will fail: (*******
I have attached the highlight file. I hope it will give you what you want
By the way, do you know how to include it inside the Notepad++ ?
Kostas
This may be a bit of an old thread, but I'm sure there are still people using Notepad++ for NetLinx code. Here's an alternative language template to the one provided by Kostas which people may find useful. The joy of these is that it's very easy to change font styles and the like to suit what works for you.
Andy
Have you played with Sublime Text 2 at all? I switched from N++ to SB2 a while ago and haven't looked back.
http://www.sublimetext.com/
Do you have a language template for Sublime?
No I don't. I use Netlinx Studio for AMX programming so debug, compiling, and transferring are all in the same place. I would love to use ST2 for AMX programming, but I don't see that happening.
Andy
