Shelf EQ not possible?
I have a London Soundweb 160 which and I have just received presets for my speakers. The presets require that I use a shelf EQ where I set frequency, gain and Q. To my surprise, I cannot seem to find this kind og filter on the BSS unit. Its possible to make a shelf but I cannot set the Q value.
The preset requires Freq=4,5khz, Gain -12db, Q=9.
Is it really true that this is not possible on the Soundwebs? The presets are for the Crown DSi/XTi amps which have this possibility and is way cheaper/simpler than the BSS units.
Compare these results: (see picture below)
One is the Crown DSi amp and the other is the Soundweb london. This will not result in the same speaker tuning.
Hmm anybody?
There is no relation between Q and slope. Q does not apply to a Shelf EQ, despite what the Crown amp control panel displays.
But I am confused about the Q value of the shelf too. Maybe there is a way to make the same setting by using the standard shelf from the BSS in addition with a single bell-filter? I just dont know the conversion.
I think that best you can do is match the EQs up visually or by sending pink noise through them and matching the resulting spectrum analysis.
I have used measurements for setting up the speaker now and it sounds great. But I would still like to have the original settings just to make sure eveything is as JBL wants it do be.
