FDS-366T OS limitations for firmware uploader?
autopoiesis
Hi all,
Have 2 x FDS-366 - no mention of 'T' or 'NTM' on front panel, but loading screen says FDS-366T, A2.04 on both units; NTM36/52 filters available.
I have downloaded the A2.06 firmware, but no firmware change log to be found.
One unit froze at one point, but worked AOK following restart (could be a dodgy cap/solder joint); I'd like latest firmware - on principle - but not risk bricking the unit getting there...
Updater help file says \"Under MS Windows 95 or 98, start the File Transfer software...\" - does anyone know which 21st century OS versions (XP, 7, 32/64-bit, etc) are known to upload correctly (or known not to!)?
I have an old WinXP box (with proper serial port) somewhere if need be, but 95/98 could be tricky!
TIA for any advice,
AP
TIA for any advice,
AP
The 366 Loader works fine on XP and 7 32 or 64 bit. If using a USB-Serial adapter then the Prolific or FTDI chipset workreliably.
Firmware A2.06 fixes the Alignment Assistant.
Kudos to BSS for continuing to support users of long-extant, but still highly useful, equipment!
Best wishes,
AP
In future, please contact tech support. We can help with most equipment no matter how old.
