The details are greyed out because your PC is not in the same IP address range as that of the Dante card. The IP address of the Dante card can only be changed when the PC and the Dante card are in the same IP address range.
Dante Controller will discover the Dante card and display it's IP address. Simply sert your PC with an IP address that is in the same range. Then the details will not be greyed out and you will be able to change the card's IP address in the Network Config tab.
I did this and all the fields in the network area of the DANTE controller are grayed out. I need to check the version of the DANTE controller.
