Time adjustment on a blu device
Hi volks,
haven't been here for a while, but now back with a question :?
I wasn't using calender stuff on soundweb in the past, that's why I didn't care for the time on the devices to much. But now I'd like to use it, so I would need a way to adjust the time on the devices.
I hope there is another answer appart from \"If you go online, system time is pulled from your pc...\"
I don't believe there is a ntp client or similar, but hopefully there is a way adjusting time by ethernet or serial.
Regards, Rolf
Regards, Rolf
expected this answer, but what about the \"third party control interface kit\"
there it is possible to set the time.
And found in AudioArchitect a message to subscribe to the time of a device.
But I can't interpret the answer. Do you know how to decode the time returned to the subscibe message?
Maybe If I know how to decode/encode the time string, then I'll be able to understand how the set time function in the control kit works.
This would be realy needed! Would solve me a big issue, so any help aprecheated.
Regards, Rolf
This was setting the time maybe around 2:40pm on the 15.01.18
02 88 00 00 00 00 00 00 00 1b 82 5a 5c bf db e8 03
so message type 88 is a \"set value\" command
hiqnet address 00 00 00 seems to be a broadcast.
register 02 is the system time
but how to interpret 5a 5c bf db as date and time????
can anybody help????
5a 5c bf db (4-byte Hex) = 1516027867 (decimal)
Go to https://www.unixtimestamp.com/ Enter the decimal number and it will convert it to a time and date.
