Crown Macrotech 3600vz
Hello guys, I joined the forum because I’m in a bit of a pickle, I’ve acquired a Macrotech 3600vz and it has a pip card so it can be controlled by computer, well I don’t want to run it that way but when I try to use the quarter inch inputs I don’t get any signal, now when I disconnect the card I get a signal but it’s not hitting as hard as it should, now I don’t know if it’s programming or something I’m not physically doing, please let me know your thoughts and experience, Thanks
Unless you want to replace the pip card by the standard version, I would bypass the card and use only the 1/4" connectors. Just splice the jack connections to the input connectors on the main board.
Alain
