Crown XLS602D Bridge Mode
Hi :) . I am new to the forum. I have a crown amp XLS602D that I'd like to use as a mono amp. This particular amp has a bridge mode switch which is to my knowledge the newer revision of the XLS lineup. However I couldn't find any wiring setup for this newer amp (just for the old ones without the switch by making a custom Y-cable). I don't want to do anything without an expert's advise. Any help would be appreciated. Thanks!
  • scytechscytech Posts: 148
    Usually, a bridged amp receives its input signal from Ch1. Also, load is taken at the two positive output connector.
    Alain
