Change input voltage 110v to 220v Crown XLi 1500 amplifier
Good morning all !
I live in French Polynesia and I imported a Crown XLi 1500 amplifier from the USA. Its operating voltage is 120 volts at 60 hertz.
Now I want to run it at 220 volts 60hertz (this is our standard in Polynesia).
I opened the beast to remove the power supply and everything seems to indicate that the components are ready to run at 220 volts (or even 240 volts).
If so, can someone qualified tell me which component should I modify / replace to make the voltage change?
Any help will be greatly appreciated!
IMHO: Use a 240 to 120V transformer. It will probably be cheaper than having to do a mod and void warranty!
Alain
