Xti 1002 goes into thermal
My xti 1002 does into thermal with no input or output connected to the amp
I assume that the unit has been on with no input for some time and eventually goes into a thermal event? Does the fan operate at any time during its operation? Access thermal settings through USB and activate fan on a different thermal setting more appropriate
I assume at this point that the fan is obtrusive when activated. And perhaps deactivated! Some users have success controlling fan operations by setting the amp on its 'rear' so that heat elevates through the front vents. Apparently, the fan is not used and amp is silent! However, rear end would need to be raised because of input and output connections.
thanks
