Home Crown User Forum Crown Microphones & Mixer-Amps
CM-312
Bought one from AMS a year and 1/2 ago- went to use it- wouldn’t work. What should the actual working part of the mic look like?
  • nojoconojoco Posts: 32
    It should look like (and function) the same as any other mic. Do you have phantom power available to it? Are you using a battery for phantom power? If it all possible, I recommend not using a battery for phantom power, but using phantom power provided from a console. The battery option should only be used if no phantom power is available from a console. Does the mic have a "mute" switch (sometimes found on the cable)?
