Home dbx User Forum dbx Software
Front panel update required
My dbx driverack pa2 was workinf fine until one day i turn it on and the screen says ‘front panel update required’. It does not respond to anything at all. I’ve tried soft and hard reset with no luck. Any suggestions?
  • walfrettwalfrett Posts: 10
    I got it sorted out. Up and running again
  • HARMAN_RobHARMAN_Rob Posts: 231
    @walfrett glad you fixed it! May help the group in the future to know what happened and what you did to fix it; could you let us know more?
    @HARMAN_Rob my dbx driverack pa2 was powering on, but stuck on a screen that said ‘front panel uodate required’ and would not boot pass that. Called tech support and they sent me the file for ‘manufacturers update’, i followed the prodecure and that helped my situation.
  • agdonardoagdonardo Posts: 1
    Meu dbx driverack pa2 foi workinf bem até que um dia eu ligá-lo e a tela diz 'atualização do painel frontal necessária'. Não responde a nada. Eu tentei uma reinicialização suave e difícil sem sorte. Alguma sugestão?
  • jayrjoejayrjoe Posts: 3
    Hello
    I have the same issue, FRONT PANEL UPDATE REQUIRED
    Please I need a fix for this asap, I have a few gigs line up in the next 2 days.
    Thank you
    hello walfret, please share how did you fix it
    Hello....
    @jayrjoe : walfrett called HARMAN Pro Tech Support.
  • Hola, tengo el mismo problema, alguien me pueda ayudar
    feelingentretenimiento@gmail.com
  • Walfrett pls help us... maybe it work also to my dbx venue.pls
  • @walfrett said:
    @HARMAN_Rob my dbx driverack pa2 was powering on, but stuck on a screen that said ‘front panel update required’ and would not boot pass that. Called tech support and they sent me the file for ‘manufacturers update’, i followed the prodecure and that helped my situation.
    @djkenneth : as stated above, walfrett called HARMAN Pro Tech Support. I would recommend you call as well.
    Hola HARMAN ROB, algun numero para llamar en mexico?
  • EEldeEElde Posts: 1,376
    Contact via email, we do have one Spanish speaking support specialist here, but we can generally use Google Translate as well to get you sorted:
    hprotechsupportUSA@harman.com
  • choicechoice Posts: 2
    I need help with : Front panel update required
    dbx PA2
    Contact tech support via email to request the Manufacturing PA2 Firmware Updater
  • KrisdaKrisda Posts: 1
    Requesting solutions and software files (dbx DriveRack PA2 FrontPanelUpdate Required) Send via email
    Toomtamchiangmai@gmail.com
    edited July 2020
    You can download the PA2 Manufacturing Firmware Updater here:
    https://drive.google.com/file/d/11jd2vWlVjO5Z3pfYK9RzEgVQ1EeNFi8F/view?usp=sharing
    You will need a USB Cable and a Windows PC. Instructional how to .pdf is included in the .zip
  • engboogie requesting solution to dbx pa2 front panel update
    Well, if you look at the post right before yours, it has the instructions and updater there @engboogie
    :D
  • mbahgerrymbahgerry Posts: 3
    thanks walfret....
    You can download the Updater here. I am closing this thread
    https://help.harmanpro.com/pa2-manufacturing-updater
