Settings
NUMBER ONE REQUESTED
I have 8 double 18 yamaha cw-218's running each with a qsc 2402 in bridge mono. The cabs are rated at 1200 watts each and are subwoofers. for mid range I am using JBL JRX double 15's with qsc 3402 in stereo to a set of two speakers for a total of 8 JBL JRX. For horns I use JBL 2420 1 inch horns. I would like to know what is the best settings for I should use to recieve the optimum output for my entire system espsecially the bass. I would like a heavy chest pumping but round bassline how can I achieve that. As of now the system sounds very very good. It is a very clean system I just want more. What settings should I use for crossover such as the filters and is there any delay I should use.
I guess I could do something off the top of my head...
HPF BW18 @50hz
LPF LR24 @ 120hz
thats the subs
HPF LR24 @ 120hz
LPF LR24 @ 2khz
the mids
HPF LR24 @2khz
out (means that there isnt an LPF and that the speakers will determine the upper limit with there natural limitation)
Delay the tops around 8 - 10ms
But this is just a rough setup, and I have no concreteevidence to back this.. see if you can find the actual crossover point that JBL suggests for the horns...
remember to do a gain structure and ballance to taste afterwords...
2420.pdf
It states the recommended crossover freq to be 800 Hz or higher.
The absolute lowest I would consider is 1750, but be prepared to replace the diaphrams on a much more frequent basis...I'm sure JBL would love to sell you those... Even in monitor use those won't hold up crossed out below 2000 hz! 30 years of speaker building boys.. I have made the mistakes.. had the failures.
As always, heed the word of Gadget...he da man.
C
