Mono sub output into two amplifiers?
I just got my Driverack 260 and can't figure out how to route the outputs.
I am running passive tops in stereo with an amp in stereo
I am running the subs in mono with a separate amp in bridge for each sub.
In the stereo main / mono sub configuration, the outputs of the driverack are 1. Left 2. Right 3. sub
How can I route the sub to both outputs 3 and 4, or 3 and any other output?
I was under the impression that the stereo image disappears with lower frequencies. Thus, sub should be run mono.
The 260 can route any input to any output The config button allows access to the different crossover configurations, and to the delays to allow reconfiguration...the manual shows 2x3 and 2x4 and are easily asignable.
Low end is omnidirectional, but if you had several subs you can do power shading with them.
let me know if you have further questions
gadget
http://www.driverack.com/drug/view_thre ... d_id=41598
Look at the the file that says 260passivetopsdualmonosub.
Maybe Gadget or someone else has a better way to do what you want, but I didn't see any other way.
Kenny
The lightbulb just went on...
I opened the file you created. It took me about a minute to understand how the driverack config works. I read the manual a half a dozen times and could not grasp the setup.
Thank you again!
