mixing custom and preset settings
Here is my question/problem.
I have 2 CE2000's Bridged pushing 4 JBL SRX 4726's and 4 RMX1450's Bridged pushing 4 Yamaha SW218v's.
Current DRPA setup: Presets for the tops and custom for the subs with the X-over at 90hz and the gain set to 0DB.
Where I am confused is at the x-over, I am not understanding the in/out setting. I think I'm just a little slow (I rode the short bus for a week) but in the analog world I set the freq for Hi/Mid/low and that was it no in and out setting.
I am thinking of buying the RTA microphone this weekend and play with it for some fine tuning as well. Will it help setup the delay or does it only adjust the EQ settings?
Thanks for any help in advance.
I usually recommend a BW 18 for the HPF and since you have inadequate power for the subs I'd recommend a 45-50 HPF. The 90 HZ lopass is fine I would recommend the LR 24 filter and delay the tops 7-9 ms. No the auto EQ does NOTHING with the delay, PEQ's, or anything else...ONLY the GEQ will be affected.. All other parameters need manual setup.
Go over to the other site (FORMER FORUM) and read all you can there is a lot of information I have provided over there...
gadget
