2x2 configuration on Drive Rack PA?
Greetings,
I run a simple church set-up in which we have 4 JBL EonG2 speakers, and we daisy chain the two front speakers together and daisy chain the two side speakers together. All 4 speakers are two-ways and have essentially the same mix sent to them (I don't have a need to send the lows, mids, and highs to separate speakers--we also don't have any subwoofers). Does anyone know how to run a 2x2 configuration on the Drive Rack PA? The only options the manual lists are 2x3, 2x4, etc. and not 2x2. I'm currently sending the left DRPA output to the two front speakers and the DRPA output to the two side speakers.
Nathaniel
Nathaniel
Nathaniel
2nd option. Repeat above, but select a \"custom\" sub (stereo) and amp. Go into the x-over. Next page until (H) comes up and roll the freq down to where you want it for the low limit(speaker specs may advise). Hit Next page button again until (L) comes up and do the same with the low limit, next page and set the High limit (out). Outputs - One set can be Hi - Left, one set can be Low - Right. You will have access to 3 bands of post PEQ for the Hi set, but only 2 bands for the Low set. Feedback will still be common, but the delay will now be functional for the side speakers up to 11 ft in front of the mains.
Hope this helps.
