Aux fed subs & drpa
Hello,
I'm beginning to experiment with feeding my subwoofer from an auxillary mix. This allows me to create a separate mix for the subwoofer where I'll only route keys, bass, kick drum, etc. post-fader into the subwoofer and I'll be able to control the volume level of the subs from the aux master send. These signals will also be sent to the L/R main mix as well. I experimented with this the other day and the kick drum is now finally beating my chest and the guitars are really cutting through the mix.
The issue is that I haven't figured out how a way to route two separate mixes into the DRPA so that I can use the x-over for the aux mix as well as the tops and so that I can eq the subs separately from the tops as well. Perhaps it wasn't built for this. If not, I'll continue to use it for the tops and get a separate processor for the subs.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
Sure its possible, it would be easy with the 260, but the DRPA has limitations. One is that the dynamics are tied together...The signal is separate for the GEQ's, Xover, but not the Comp/limiters, AFS, sub harmonic synth, even the PEQ's post Xover are tied together for each band.. So.. If you were running a three way top mains you would not have the ability to do so. If however you were running two way tops, and subs you could... you wouldn't be able to utilize all the functions.. and you would only have 2 bands of PEQ... but it is possible...Look at the block diagram on page 4 of the manual and you'll see the routing limitations...I have provided along with others, a wealth of information at the FORMER FORUM you can access above in the Tutorials and user submitted white papers, and use key word searchs to get a ton of info.. we have been doing this for years.
I do like the idea of being able to control the mix of instruments separately for the sub but I haven't done it live yet, only in rehearsal under very controlled circumstances. It seams like I'm losing alot of the DRPAs functionality if I route the sub mix into the DRPA. I'm now thinking that the DRPA probably doesn't do a whole lot for the sub mix anyway. The sub mixes frequency bandwidth is only from 20hz - 120hz so there's not much to EQ. Compressing the kick drum or bottom end of the bass doesn't make too much of a difference in my mind either. Probably not going to have too many feedback issues with the sub mix either. Therefore I'm thinking I'll just run the main mix into the DRPA and route the sub mix directly into the subwoofer and call it a day. Any thoughts? Am I missing something? I appreciate your time and help.
I have never aux sub mixed. I've read good things about it, but I would be concerned about the upper registers of the bass guitar and keys getting lost. Unless you routed them back into the mains mix. Well now I've done it, I'm confused. Gadget???
Later,
