260 sub delay
Hi, I am getting ready to install a 260 in a house gig live band situation. The tops are 4 yorkville U15p's (powerered boxes w/ dsp and x-over in the box), and 8 klipsch kp 480 front loaded 18\" subs. I want to delay some subs to avoid the power alley of low end on the dance floor. I want four channels of subs (two boxes on each channel) and two channels of tops. How do I configure that setup correctly? Thanks guys, Matt Jordan
http://www.driverack.com/drug/view_thre ... d_id=41737
That should get you started... BTW it was all done in the wizard...in the config mode you can redistribute the delay / set the crossover configs.. etc
Open the 260. Right click on the \"Driverack 260\" banner and select import.
That is NOT an openable file ... You could defeat the filter it is probably best if you do since I have you crossing over there any way.. BTW I did that because the U15 is weak in the sub 100 hz region anyway...
gadget
