Link Inserts
I'm running stereo triamp.
Is there a way to link the inserts (feedback, compressor, etc) from within the GUI? I can do it on the front panel.. I can UNLINK things from the GUI by right clicking them, can not figure out how to link them back together!
gadget
For example, linking the Advanced Feedback Supresssion across inputs A and B.
Possible?
Man, user forums are great.
Did you try what I sent you? If you:
in the GUI click the \"config\" button just under the \"program\" button...right click the parameter you wish to modify.. modify, and then click \"config\" again...
you link and unlink the modules... add and subtract delay, change crossover configurations...insert different modules...
Are you using the GUI? If not why not...I don't get it...
gadget
:-P
I have the image on the top. What I *want* is the image on the bottom -- linking the feedback insert across the two input channels.
Either I'm missing an obvious check box, or I'm missing a concept of audio theory that precludes me from doing this.
If I right click the GEQ in the pic above, I get the option to \"unlink.\" Fine, I can unlink it.. but can't figure out how to link it back, or to link any of my inserts together.
Thanks DRA!
