Sharing aa insert device
Dra
This is not technically a Driverack question, but there is one in the rack. Ha
I have a common set-up where a podium has 2 mics for various pairs of MC's of differing heights and vocal projections. Because of this I have to CRANK the mics. I insert a AFS224 on these channels so I don't kill the over all mix for singer, music, etc. Is there a way to tie 1 side of the 224 to 2 channel inserts at the same time, thus saving the other side for another problem mic if needed? This solution needs to be \"wiring\" solution.
David
David
gadget
I kinda think I need to avoid a third problematic mic situation.
David
Ya but you could send the signal out of either monitor send )they are pre fader)and into the 224, then out of the 224 and back into one of the channel strips on the mixer that way you can sum pre 224 and process post... should work and you'll only need two 1/4 x 1/4 inch cables... that other way you are changing impedances, causing interactions between channels and who knows what...I'd be careful trying that... It would probably work, but not well. So what do you think?
David
