Monitor Set Up
Hey fella's, happy Fourth of July!
I have a fairly easy question. I run (4) 15\" stage wedges for monitors. I used to push them with a QSC RMX 850 in mono, then just daisy chain the monitors together. However, I just bought a new RMX 2450 to replace the 850. My question is, should I continue to run the 2450 in Mono and daisy chain all four monitors.....or, run it in stereo and only daisy chain two monitors per channel. I assume running the two channels would be better for the speakers as there is not as much juice flowing to one speaker, plus two channels could give me two separate monitor mixes. What's your opinion(s.)
(Specs)
RMX 850 - 530w @ 8ohms bridged
RMX 2450 - 1300w @ 8ohms bridged or 500w @ 8 ohms stereo
Thanks!
Dan
(Specs)
Thanks!
Dan
Dan
My monitors run from an aux send on the board to a 31 band EQ then to a feedback suppressor then to the amp. The EQ and FB supressor have only one XLR out and one 1/4 out. (I used the XLR out as I only needed one because I ran the RMX 850 in mono)
Now, should I run a second line from a second aux send out of the board, through the EQ and FBX then out the 1/4 inch to an XLR in on the amp? Basically use the XLR and 1/4 outs on the FBX.
Or do I simply use an XLR \"Y\" cable and split the signal after the FB supressor but before the amp? (Keep in mind these are just monitors, not my PA mains)
Yo! Dra.. yes .. they demo those amps by using a piece of iron and shorting one channel out ..thats right arc welding style..and the other channel keeps on chuggin and the shorted channel comes back to life as the odep circute recovers...
As you have seen we have run the Digam 5000 with three LABsubs per side thats 3.5 ohms per cab...all day outdoors...which is 1.66666666666666666666666666666666666666666666666666666666666666666666666you get the picture...
I have a Mac 3600 that we ran 8, 15\" drivers in high current bridged mono.. it was all fine and good till it threw 4 cones out on the dance floor flaming.... :shock: \"OOPS...\" my son said of the experiment :roll: ya... thats me rolling my eyes...and opening my pocket book....good thing I'm a re-conning center huh :?:
Dan
