DBX DriveRack PA / Yamaha / QSC Configuration
I would like help with following setup so that I can make sure that I am getting the maximum out of all of my components. If I am leaving any information out that is needed please let me know.
(1) DriveRack PA
(2) Yamaha S215V Frequency Response 42Hz - 16kHz
Power Capacity Noise 500W
PGM 1000W
Max 2000W
Nominal Impedence 4 Ohm
Crossover Frequency 1.5kHz
(2) QSC RMX1450 (Bridged Mono) 1400W @ 4 Ohm
These are each going to one S215V
(2) Yamaha SW218V Frequency Response 30Hz - 2kHz
Power Capacity Noise 600W
PGM 1200W
Max 2400W
Nominal Ompedence 4 Ohm
Crossover Frequency 90Hz / 12dB/oct.
(1) QSC RMX4050HD (Stereo Mode) 1300W @ 4 Ohm
Each channel going to SW218V
I would like the complete setup procedure for this amp/Speaker combo if possible. I am new to the DBX DriveRack. I did use the Wizard for initial setup but still feel like I am not set correctly. I noticed it didn't give an option to show that the High power was bridged. Any help would be greatly appreciated.
(1) DriveRack PA
PGM 1000W
Max 2000W
PGM 1200W
Max 2400W
Also download the Driveware GUI. It will help you understand a lot about the DRPA.
