New User - May be a loser!
visoundguy
Hi All,
Just purchased a Driverack PA at the prompting of a friend who felt I could eliminate a bunch of stuff in my rack. I also was tempted by the RTA capabilities as I'm a newbie at using an EQ and had nothing to EQ a room with. I've done everything the hard way - and thought this thing would offer push-button convenience.
I have (at least) 2 problems: 1. I didn't do my homework. 2. I have custom built (in my basement) speakers and 4 Samson SX 2800 amps. I have homebult Dual 18 subs, 2ea 2 X 15 mains with horns, and 2, custom built 2 X 8\" speakers to fill out the mid highs!
I can get my setup to sound pretty darn good Manually, but it's very inconsistent and I had hoped to gain more consistency and a bit more headroom with this unit.
My question is - since I have a homebuilt rig, should I even bother with trying to set this up, or is it a waste of time? If I should give it a go, I'd like some advice as to where to start. If I should give it up, I have a Driverack PA for sale!
Thanks for any help you can give.
No problem,...and yes the DRPA will make a significant difference... Do you have the specs on the drivers or the cabs that you built in regards to frequency response?... Also,...I would like to know the number of drivers in each cab and the total impedance (4 or 8 ohms) of each cab... Also,...can you give me the specs on your amps... How many amps are you using for subs, mids and highs?... Are they used in stereo or bridge mono mode?... I can give you a good custom starting point for your DRPA if you can give me a good idea in how your system is used and what it's capable of... So basically,...the more info, specs, etc., you can provide the better...:)
Just looked at your amp... It appears to be a QSC RMX2450 clone,...just like the Behringer EP2500 and several others...:)
Kev
PS. Dra and Gadget take a break,...I'll field this one...:)
So here it goes:
I’m using 1 SX 2800 in Bridged mode for each Dual 18 subs
I’m using 1 SX 2800 in Stereo on the 2X15 mains
I’m using 1 SX 2800 in Stereo on the Highs
I’m using an active crossover on the mids and highs
I’m using a Sub output on for the subs on my EQ – Behringer FBQ3102
Here are the specs on my Home-Builts:
2 ea Cabs – 2X8 speakers with 2 8� woofers and 1 tweeter in each cab
8� Woofer specs
· Type: 8\" Woofer/Speaker
· Power RMS: 75 Watts
· Power Peak: 150 Watts
· Frequency Response: 60-5K Hz
· Sensitivity: 94 db
· Magnet: 30 oz
· Voice Coil: 2\"
· Impedance: 8 Ohm
· Die Cast Aluminum Chassis
· Paper cone
1.5� titanium drivers
RMS Power 50
Peak Power 100
Ohm 8
Efficiency 102db
Frequency Response 1.5khz-20khz +/- 6db
Voice coil/Diaphragm 1.5\"
Magnet Size 20oz.
Type Diaphragm Titanium
Throat Size 1\"
Other Ferro Fluid cooled
2ea 2X15 cabs – modeled after the Peavey 2X 15 cabs
Woofers:
15 inch woofer with cloth accordion edge. 35 to 2k Hz. Average sensitivity at 1w/1m=100. Magnet weight is 130 ounces, 8 OHM, 500 watts rms, 1000 watts peak. 4 inch voice coil. size 15.25\" x 5.75\" , Weight 25 lbs
Tweeters
RMS Power 50
Peak Power 100
Ohm 8
Efficiency 102db
Magnet Size 20oz.
Throat Size 1\"
2 X Dual 18s
18 woofers:
18 inch woofer with cloth accordion edge. 25 to 2k Hz. Average sensitivity at 1w/1m=100. Magnet weight is 130 ounces, 8 OHM, 500 watts rms, 1000 watts peak. 4 inch voice coil. Outside diameter 18.75� Minimum cutout size 17.00�. Size 18.75\" x 8.0\" , Weight 27 lbs
I'm assuming that your 2X8s and 2X15s are passive with their own crossovers?...
Kev
No problem... Please be patient while I cook you something up... It will take a little while...:)
Kev
Thank you for putting up with us Newbies and doing your best to help. It's above and beyond the call!
It's very appreciated.
Thank you for recognizing the DBX user group!... Obviously you understand that we donate our time to help others... We all need help at one time or another (an understatement for me :? ),...and besides \"to teach is to learn\"...:)
The following suggestions are only my opinions or personal preference... When setting up a system like this there are going to be trade-offs...and the main goal is to come-up with something that sounds great to you...
I would use a custom 2X5 stereo with mono sub configuration as illustrated below... I used the DR260 DriveWare Wizard to configure this custom 2X5 as a starting point...
2X8s in Stereo:
HPF 108Hz L-R24dB/Oct
LPF Out BS6dB/Oct
Gain 0dB or maybe -1dB if to much on highs
Note: The following is very radical and unorthodox but I know from personal experience that your system will kick a** if your 2X15s and dual 18 subs are in phase... If you don't like the way it sounds you can always set your 2X15s the same as your 2X8s...:)
2X15s in Stereo:
HPF 72Hz (or 108Hz) L-R24dB/Oct
LPF Out BS6dB/Oct
Gain 0dB
Dual 18s Bridge Mono:
HPF 41Hz BW18dB/Oct
LPF 105Hz L-R24dB/Oct
Gain +3dB
I suggest a \"3dB boost\" for your subs... Personally,...I love lots of earthmoving, chest-thumping bass...8)
I recommend that you click here and download the DriveWare GUI... Play around with the DriveWare and get yourself familiar with it... These settings should work...but you will need to key them manually with the DRPA... I would read the DRPA manual but it's assumed that the user has prior experience with PA systems... Sit at the kitchen table, poke around, and get familiar with the menus and screens… You may also want to look at the \"Training Modules\"... The tab is located at the top right of this screen... I also recommend that you read Gadget's \"Heartfelt Welcome\" post in the FAQs Start Here category and setup your gain structure...
It's not going to sound “great� until you set the gain structure, the time delay, and phase between the subs and tops, and perform an Auto-EQ (for inside use only) with the RTA mic... If you perform the Auto-EQ only enable one side (mute the other), adjust the gain (volume in this case) to the venue listening level, and use the fast mode... Once it has completed set everything (in the GEQ) from 0-100Hz flat (at 0dB) and adjust everything from 7kHz and above to suite your taste...
Cheers,
Kevin
PS: Please post back and let me know how it turns out...
I do already parallel the Subs and agree this is how it produces the best chest thump.
I'll let you know how it goes.
By the way, these amps really put out. I already can make people's ears bleed! But I want to go for some quality now instead of volume!
Thanks for your help, and I will certainly post back.
I installed nine of the Behringer EP2500s at our church's youth center... And it appears that the SX2800 is pretty much the same animal... Yes,...I bet they cook!!!
Cheers and good luck!...:D
Kev
I'm curious...how did it go?....
Kevin
When I select a 2X5 configuration on the Driverack PA, And I go in to manually configure the crossover, I can only set the HPF level on the high channel. The LPF is defaulted to OUT and I can't adjust it. I assume that's OK since that's the specs you gave me. But I was curious as to why this was? On the 260 Driveware, you can set the HPF and LPF on the High channel!
The Mids and lows are fine.
Am I doing something wrong?
If you want or need those freqs to be filtered, just set up a High-Shelf in the PEQs. This only works if you have one still available.
Side note: a repair tech said things are not looking up for B****ger. Some of the big boys are looking to file piracy conplaints. I didn't understand the whole thing but it peaked my interest.
Some how they have signed an agreement with the EU and are being \"protected\". And QSC, DBX, etc are going to put their foot down with the EU and are lobbying congress to add huge tariffs so that instead of a $200 difference between the 2450 & 2500 it will closer to $20. Then if you are going to buy an amp, it is no longer worth it to save only $20.
I seem to be remembering more of the conversation.
Hey,...it looks like we bought a building today...
G recommended (one of several) the P7000S. From what I read (PSW, gear house reviews, and Yamaha site), it is VERY reliable, but is weak on damping (under 200) and several on PSW love the amp, but not for sub duty. Most prefer a \"real\" power supply for subs, not the new light weight ones.
Later,
Now I understand it less.
One of those \"Is, but it ain't. Except on Tuesday, and the occasional Wednesday is barometric pressure is below 67.7mb.\"
