\"clip\" indicator on DRPA's display
My question relates to the display on the DRPA. Occasionally, the clip indicator flashes.
My question is; What is clipping? All the info I have found says nothing about if this indicator comes on what to do about it.
Is the input clipping? The output? One band, or all bands?
Someone please help.
Dale
Dale
if it's on the inputs... turn the source down.. I.E. mixer master outs
if its the outputs...turn the crossover gains down.
You need to be more specific what you are experiencing..both hearing and seeing.
I will have to get back to you with the settings as I do not remember each one. I have about 6 presets for different venues. I have a show on Thursday, so I can get them then.
The meters on the high out are up to the top at times, and the limiter page shows there is some limiting. Approximately -4dB on peaks.
The mixer output is at or a few dB above zero dB out of +28dB. Mackie 2404VLZ.
I have finally decided that the output from the mixer is overloading the input limiter. This caused the word \"clip\" to display on the left edge of the display. Centered from top to bottom. It displays on top of whatever page the display is showing. ie, eq graph, limiter page, etc.
I have since found that bringing down every fader and even input trims to more reasonable levels is much better for the overall mix. Duh. \"It's the gain structure, stupid!\"
Thanks to everyone who replied.
-Dale
