I have 2 JBL SRX4725 cabs and 2 JBL SRX4722 cabs - Need Amps
First off, let me say that I am not a Pro Audio anything ..
I have a 4 speakers setup that I know I am not amping correctly so I want the right equipment for the job and am willing to pay for the right equipment... and I want it to be touring quality equipment.
These speakers all sound great .. the 4725's were reconed in 04 and new crossovers were factory installed at that time. The 4722's were purchased at that time and have been the work horses for our \"small hall\" venues ever since.
Here is the information that I have been given in the past, any corrections or advice will be greatly appreciated ..
I was told that the 4725 cabs need to be overpowered by not less than 50% due to the 15\" speakers and that the 4722 cabs need to be overpowered by not less than 30% due to the 12\" speakers. Is this information correct?
This being said..
I assume that since the 4725's are rated at 600W RMS @ 8 ohms each, I need to have no less than 900W @ 8 ohms per speaker supplied by the amp.
I also assume that since the 4722's are rated at 600W RMS @ 8 ohms each I need to have no less than 800W @ 8 ohms per speaker supplied by the amp.
The individual that told me this information suggested that I purchase amps in the QSC PowerLight 3.4 or Crown MA 3600 range.. would the users here agree?
Any suggestions or discussion about this will be greatly appreciated.
This being said..
Go with 2x the RMS (or = the Prog) rating of the cab.
Go here to see what QSC recommends for your rated speaker. Then compare with comparable Crown, etc.
http://www.qsc.com/products/amps/advanc ... lector.htm
You can go beyond 2x, but the higher that you go, more attenutation of the amp will be required not to melt your coils. Also you have to have self control if you go with bigger power than 2x.
So for your cabs, a 1200w @ 8 ohms capable amp will get your speakers as loud as they will go (safely) and the amps will have at least 3db head room to stay out of clipping.
The speakers should have (by Crown INT) 2-4 times the rated power...Hey Dra... those speakers aren't in the QSC data base that I could find...and no \"this is the closest to them\" since the design is somewhat outdated...and they don't use those drivers any more...Yes I know those and they do require a lot of juice...most JBL's do...The 4719 subs for instance require HUGE power to perform properly..like a MAC 5000 per speaker...Simple \"this amp is best\" statements aren't useful to me...For instance, the new amps that have high tech power supplies don't sound as good as the older super heavy Mac amps...The problem is, I don't think you can tell the difference with those speakers...I'd consider the MA 3600 as an excellent choice, if a bit heavy...I use them.. I love them..but In INSTALLS... not portable sound...They are just too heavy for this old man...
To get an amp that's capable of 1200-1800 watts [email protected] ohms..is gonna COST you...If I was you, and I wanted to get tour grade amps that are the \"real deal\" I'd look at Powersoft...Now they will as I said COST you. Even in the Digam line the 5000 is only 750 watts per channel @ 8 ohms.. it will however drive your speakers more than adequately...they don't make them any more however.. so to get that kind of power your either going to need to go bridged mono, or spend thousands per amp or settle for less power...
Well that's the long of it from my point.. questions?
Gary
List pricing used here.
$2500 for (1) RMX5050 1100w @ 8 per pair of cabs.
$1750 for (2) RMX2450 1500w @ 8 (bridged)
$1500 for (2) RMX1850HD 1200w @ 8 (bridged).
Crown, Yorkville, ect have amps that are comparable in output.
Better have some serious edison available with all but the Powersoft too...they are all power hungry. Maybe the QSC PL380, plx 1802...bridged...Or cheapest Crown XTI 2000...less weight, more power... less juice...
my $.02
Wouldn't it be great if someone would make 200w @ 8 base amp that like a computer could have power module plug-ins. Need 3 db, add another 200 watt \"stick\". Need more, buy the 1000w'er. 8)
Powersoft
Lab Gruppen
Crown/Crest
QSC
Peavey...like amps...
