setup driverack PA
I`m in a hurry due to tight scedule to get setup. Currently use an active db opera sub 15 with built in crossover along with two mackie srm 450 active sidespeakers.
How do I setup easily with the wizard?
-What main out do I use from the DR. Just any??
-What to select for main, sub, amp and so on in the wizard?
Guess I´ll have to do at least a partly manual setup since none of my speakers are repr. in the wizard,
-Is there an easyway to get going with the most important parameters to start with till I learn more later on.
Set the (this is without ANY REAL INFO ) HPF on the sub to [email protected] hz
Find out what the xover point of the sub is... and set the LPF just below that @ LR24 filter.
Set the HPF for the tops @ what you set the subs LPF @ (or just a few hz above) using again LR24 filter
Hi outs L/R to the SRM..
Left Mono lo out to the sub...
Do a gain structure as in READ ME FIRST BEFORE POSTING...\"Strat here\"
Read the FAQ's (the ones in the RMFBP section... lots of tips and tricks there
Stereo passive with mono sub.
Mackies connect to Hi, L&R
Sum to Low mono
X-over
Low (set onboard x-over as hi as it will go, set level to 12 o'clock to start)
HPF 45 BW18
LPF 90hz LR24
Hi (set level to 12 o'clock to start)
HPF 90hz LR25
