260 setup - Yorkville speakers
Hi,
Just got a new 260 for our church, I'm new to this type of EQ. Trying to figure out the setup. Do I want graphic or parametric?
Our speakers are Yorkville U15P's, 2 of them with a single sub in line (LS700P). How do I setup the custom speaker setup? These speakers are powered, so the amp is in the speaker. They are tri-amped with 150/150/600W from high to low. Crossover frequencies are at 1250 and 350 Hz. Sub is 700 W.
Our church sanctuary is 50'x50' with the stage and sound booth at opposite corners, chairs diagonally, carpeted, low ceiling.
Ryan
Ryan
Are you planning on using the Driveware GUI to control? Well, you should. Go to the \"Driverack Traing Modules\" link above and download (or run online) the tutorial. Then down load the Driveware for the 260 and play a bit.
Then go to the READ ME FIRST SECTION and read the stuff there. All of it will not apply, but a lot of it will answer 90% of all questions that you may have. Then, if you still have a specific question or can't quite grasp something, we'll be glad to help.
GEQ vs PEQ - GEQ is much easier for on the fly changes, but PEQ is superior tonally. For someone in your shoes (fixed and consistant), tweeking with the GEQ until happy then translating the data to the PEQ can be useful.
Good luck,
OK, got the GUI going, updated firmware and read the Read Me First... although that is going to take me some time to digest.
All I want at this point is 2x2, nothing fancy, I can add bells/whistles later. I selected "wire" for the 2 inserts at this point... ultimately will select AFS and possibly compression later on. I selected custom passive speakers even though my speakers are tri-amped... because tri-amped wasn't an option (only bi-amped). I noticed that this took away the gain control in the setup. Gadget says don't worry about that... we'll fix that in the GAIN STRUCTURE section.
Also didn't select a sub because the sub is inline and thus the 260 won't see it... the speakers/sub both have their own high/low pass filter.
Before I move on to gain structure, is this correct?
Well, you have the 260 so you can do whatever you want...the \"start here\" kind of assumes the DRPA in many ways and it is simplistic in many ways to the 260...
I think you are under a misconception here.. a 2X6 could be a 3 way tri-amped top.. a bi-amped top and a sub...you could even set up a stereo 4 way system (bi-amp tops in stereo, mono lo-mids and mono subs, I use this config) and the \"config mode is where you set this type of complex system up... in the config mode you can
Re-allocate the delay
Select between the different mono and stereo xover modes
1X1
1X2
1X3 ETC
2X1
2X2
2X6 ETC
select which input (or both the inputs) feed the different outputs
link and unlink modules
change inserts
Change GEQ to PEQ
ETC
It troubles me that you say the sub is \"Inline\"? and not run by the DR... BAD idea...get that thing on the 260...
So these are powered ? speakers? or just have passive crossovers?
When pre processing something like a sub that has a built in LPF you need to set the XOVER point below the set point of the speaker... as in a sub set to LPF @ 120 hz, you could set a 110hz xover and that would be as high as the sub would go....below the passive xover but still better than using the passive since you have all the power:
PEQ's ( a HUGE benefit!!!)
limiters
xovers
phase and delays
HPF and LPF filters
and clarity of the DSP on ALL the speakers.
questions?
BTW Compressing the whole mix in (especially church situations) can help CAUSE feedback.. especially with Lav mics in the mix.... :shock:
Yes, after thinking on it, mono sub should have own output like you say. So a 2x3 seems best. Yorkville U15P's are powered... we plug them into the wall. But only has 1 line input per speaker. They are active, tri-amped with DSP protection and 4 position delay for subs. Doesn't specify if the crossovers are active or passive, but I gotta believe they are active since they are part of the DSP.
Yes, compression is for the experienced... I'm not there yet. AFS for module 1, any suggestions for module 2?
Your gain structure procedure says to disconnect the amps, yet have the speakers connected? Either I don't understand or I can't do that with my speakers. Please explain.
New location still under construction. Probably won't get to hook DR to mixer and speakers for about 3 weeks. Using this time to learn DR and other audio stuff... your READ ME section should keep me busy in the mean time.
Website for speakers, click manual link:
<http://www.yorkville.com/products.asp?cat=38&type=29&id=346>
<http://www.yorkville.com/products.asp?cat=2&type=29&id=240>
Thanks a BUNCH!
What a shame...if the whole thing was taken as a PROJECT, and compromises were used, I think an acoustically solid, visually pleasing, budget inclusive solution is far superior to pouring money into attempting to solve the problems afterword...
Why is it that a space can be \"BEAUTIFUL\" but you can't hear a thing in there...Treatment and processing are no substitute for acoustics...do it right and the word of GOD will JUMP...out at you. Do it wrong and spend eternity \"NOT\" getting the message :!:
Make sure they have the facility set up,(wiring strung...hanging points identified and marked...) for bi-amping a hung cluster in the center above the stage...L/C/R, or at least [LR][C][LR] with the support structure for the weight of a good system...PLUS power, at least a 12-2with ground..20 amp capable outlet there... Make sure the speakers are rated for flying ...for insurance purposes... and I DO have some suggestions IF things are not \"Cut in stone\" I even have solutions that work when you can't hang a CTR cluster...
Be well
8)
Doing gain structures on active (powered) speakers is difficult at best and takes a bit of intuative trial & error. To be included in the process should be the noise of the cabinet at idle and the point that the internal limiters kick in.
This is not a NEW building, we are leasing 6000 sq ft of commercial office space. We gutted it and have now built it up. I wouldn't say things are \"cut in stone\", but there simply aren't many options. We basically have a 50'x50' room with a low (13') ceiling. There isn't much we can do with that from an acoustical design perspective. The screen goes in 1 corner, the sound booth in the other. The speakers have to go on either side of the screen with the sub on the floor in the corner... ceiling isn't high enough for a center cluster. Yes treatments aren't ideal, but it is the best we can do.
I would like to fly the speakers, but haven't got a reasonable solution for that yet. Until then they will go on posts 6-8' high. First quote I got (ATM-flyware) was $3k for 2 speakers hangers... ridiculous. I'll design and fab it myself before I pay that much. Speakers ARE designed for flying... what is your solution when a center cluster is not possible?
Electrical wiring is sound. 2 dedicated 20 amp circuits in the sound booth, 1 audio, 1 video. Max current draw of audio is <7 amps. Speakers amps are on different circuits than sound booth.
Ryan
It sounds like ATM quoted you on custom speaker brackets. They also have many \"off the rack\" solutions that shouldn't cost more than $300 per speaker.
Dennis
The ceiling is open... kind of like Caribou Coffee houses.... all the wires/HVAC/etc will be painted over. So the rafters are easy to get to. Although they are 5' apart, so there really is only 2 different configurations that will work. 15' or 20' from the corner. 15' may crowd the musicians on stage. 20' feels too far out... we'll see.
I never thought about hanging them sideways, is that an acceptable way to do it? Bass toward the center? Although I don't think they are meant to hang sideways, it might be hard to tilt them properly with the given mounting slots.
If you can get a fair price for them, Gadget's idea is the way to go. Those probably run $1300 - $1500 each, so you should be able to get $1000 - $1100 each on Ebay or PSW. That is way more than you'll need.
Dennis
The CPL23s and 27's are wall mount... can they be hung? Both are about $250 each. 250 W amp for 23's would be about $500, 500W amp for 27's would be maybe $800 each, ballpark. So yes $800-1200/speaker.
I was thinking 4 of the 23's and the sub we already have. DR 260 would work great with that setup. What do you think?
Would there be any advantage to getting speakers that the 260 has settings for instead of doing custom on each speaker?
The CPL's have brackets, so mounting would be quite easy (wall or ceiling). Did you get pricing from Northern? If you run mono, you can get by with one amp.
I don't want to run mono. So 2 amps... although each amp could run 2 speakers each if I went with 4 speakers. I just did a quick price search on the internet... nothing substantial.
At this point I'm just thinking out loud. We'd have to sell our U15's first before doing this. And I think we would have to run with the U15's for a little while anyway in the new place... until I come up with a good plan and implement it.
