Adding More than 1 ZC-3
NJSoundguy
Hello,
I wanted to know if I can install two ZC-3 on one ZonePro 640 to control scenes. In the configuration wizard, only the first controller can be setup as a scene select. I need to be able to select scenes from two different locations.
Thank you in advance for any advice.
Dean
Dean
Unfortunately, you cannot use two ZCs to control any one parameter within the ZonePRO series. This is because these ZCs work on DC voltage and resistance. You can, however, use 3rd party control to control the same parameters from two or more locations. However, this does bring the cost of the system up substantially.
Hope this helps.
Mike.
What I've found is that in the Config Wiz, I cannot do this. If I change the source selection of a zone to the ZC-8, it also changes the VC from the ZC-1 to the ZC-8. Am I doing something wrong, or will I have to just get a ZC-8 for each zone?
Would it be possible to use the combination of ZC-3 and ZC-1 instead of ZC-8 and ZC-1.?
This would work if you use a ZC-3 instead of the ZC-8.
Hope this helps.
