Feedback from 260?
Hi,
First time hooking up new mixer in new facility. Initially took mixer to powered speakers directly with iPod as ONLY input to mixer to get basic sound check. Worked good for 10-15 minutes.
Then I put the 260 in the chain - 2x2. I've been playing with the GUI for a few weeks now, setup was pretty basic, all from the wizard. I have a AFS module in there, but I'm 90% sure it was turned off. Custom passive speaker settings. I didn't adjust anything yet.
Within a minute after powering up the speakers, they started to feedback. Instinctively I killed the 260... that didn't help. So I ran up and killed the speakers. I restarted the 260, checked the board (all faders down). Turned speakers back on... same thing.
Restarted everything one more time and it worked fine. It's difficult for me to know where to start... is this a 260 problem, a speaker problem or power problem? I can't believe it has anything to do with the iPod or mixer. Both speakers did this at the same time, leads me to believe it isn't a speaker problem, but probably the 260. What would cause this?
Ryan
PS. Other thing I noticed is that the volume level was a lot louder without the 260 than with it. Any ideas?
Ryan
Dennis
Dennis
Dennis
If they are all on the same power try powering the speakers up with ONLY the cables that run from the Driverack... if quiet, plug one at a time back into an UNPLUGGED 260...if still no buzz...WITHOUT anything hooked up to the inputs... power up the Driverack... still no buzz.. plug in one input at a time.. otherwise report back on when the buzz DID return...
Sorry to jump in Dennis, thanks so much for your input...something just wasn't right here...
Dennis
The speakers are powered. I am reasonably sure the speakers are on a different circuit than the mixer/260. I will determine this. Either way, one 20 Amp circuit isn't enough to handle all the sound booth components AND the speakers. They have to be on different circuits, although preferably on the same leg of the electrical box.
The signal to each speaker is ran through an aux on 2 different snakes, which are in 4\" PVC under the floor. What if it ran past a HVAC unit or something like that, could the snake pick up interference that way?
I am not clear on \"The signal to each speaker is ran through an aux on 2 different snakes\". Please elaborate.
You said when the problem happened before, you shut off the 260 but the problem continued. Perhaps you would have had better results disconnecting the 260's power cord which would have disconnected the 260's ground connection. Again, this is assuming the problem is a ground loop and I'm still not completely convinced.
You said \"What if it ran past a HVAC unit or something like that, could the snake pick up interference that way?\"
It's possible but not the first place I would look. If you have the time, you could check the 4\" PVC route.
Dennis
2 separate snakes, 16/4 each. Wall box on each side of stage. Speaker on each side of stage. So I ran the signal from the 260 through one aux on each snake to each powered speaker.
If it is a ground loop, what is the solution?
If this happens again, what should I do in what order?
Maybe mute first, then 260 power switch, then 260 power chord, then run up and kill the speakers... that takes a lot of time.
mute outputs of 260
Disconnect mixer signal to 260 (inputs)
Disconnect 260 signal to speakers (outputs)
Take note of when noise stops
Report back to us.
All of these operations can be done at the DR260 and we are assuming that, once disconnected, the speakers wont make noise by them selves. Don't reconnect anything without powering down.
Dennis
Ryan
Dennis
It's pretty easy to set the gain structure on the mixer to get unity on the channel and master meter. But I haven't done that on the 260 because I didn't understand how. I think I have a clue now... hopefully.
Dennis
Dennis
The 260 saw the exact same input level. The output level was probably +15-18 db. I'm not sure where clipping is on the 260, but there were no read lights being lit up so I left the 260 channel gain alone at unity. Why is the output level higher if the gain is set at unity?
So this seems to be about right. The problem now is that when I play something on the Yorkville U15P speakers, it POPS with anything past unity on the console. What causes speakers to pop? The gain on the speakers is set at unity... I also tried it at one notch above unity. I think there is something wrong with the speakers, the volume just isn't there from what I think it should be. Any ideas?
Ryan
How did you set unity on the channel with Ipod?
But when I was looking at the gain in the 260, I was using a pink noise generator from the console, directly to the LR meter, no channel associated with it. I gained it up/down such that the main faders were at unity and the main console 12 LED was at +9 db.
Although maybe it would be better to do everything at 0 db. Set the console reading at 0, the 260 output to 0, etc.
Ryan
Oh wait. If I had +9 coming in, but the M was set at unity, then that is the problem right? If +9 coming in, shouldn't I set the master to +9. I'm confused, what is the M used for?
Do you feel there is a down side to setting your entire gain structure at unity?
Dennis
So for my situation, setting to unity makes more sense. But as I said, I'm not an expert... closer to a novice.
Dennis
Now (amps still off), you would set your limiters. Shoot pink noise through the board and bring the meters into pretty steady but bouncy max (maybe 50% cycle). Now, check the 260's input meters (GUI is better because the graduations or smaller). They should be absolutely no higher that +18db (I think +22db IS clipped (+20 max) and that is BAD). Shoot for +16 or less. This is where the input gains are used to bring down the level coming into the 260. The crossover gains control the output levels (also +20 max). The input gains also are used to reduce the noise level when needed. I don't feel comfortable advising on the limiter setting with powereds, because there are so many things to consider. Maybe Gadget will chime in.
Does that help?
Dennis
