Connecting Lexion 300 to DBXPA
My small Church just purchased a Lexion 300 as add-on to our six month old DBXPA and a Peavey PV14 Mixer. Our mixer does not have external effects input/output but the Lexion 300 has 2 Balanced XLR input and output. My question is can I run main signal from the mixer to the Lexion 300 and then into Driverack ? Please I need help.
The best way to connect it is... using a 1/4\"(1/2) (TS) cable go out the AUX SEND to the input of the Lexicon. 1/4\"(1/2) back to a channel (I'd use 10, but it really doesn't matter), but not INSERT. This way any channel that you want the effect on, you simple turn up the channel AUX. The amount of effect is then controlled by the (#10) fader. IF that unit will do simultanious(simultaneous) different FX (1 in L, the other in R) then you have the MON send if available.
You can \"insert\" the unit directly into a channel(s) using an special insert cable, but the effect can't be controlled except by a bi-pass button.
Hope this helped.
When Gadget sees that, It's going to be payback time.
Dennis
DRA(1/2)
Dennis
\"This way any channel that you whant(WANT) the effect on\".
Didn't catch this one.
What one?
Never mind.
DRA(1/2)
But I want effect to be on 10 channels and reserve remaining 4 channels for instrument.
His other comment was... that if it is a dual mono/stereo processor AND you had 2 aux sends you can use, you could have say a Verb on the A channel of the EFX processor and send it to say 29, and have a Delay on on channel B and send that to channel 30, and still have the CD on channel 31/32...
