Best way to connect dbx afs224
I need advice on the best way to connect a dbx AFS224 to our very modest PA.
Yamaha MG16-4 Mixer
QSC 2450 Amp (1 channel Mains - 1 channel Monitors)
Yamaha C115V (2) speakers
Harbinger HX121M (2) monitors
Shure SM58 (2) SM86 (1)
We are a four piece classic rock band playing small to medium venues.
Yamaha MG16-4 Mixer
Run FOH stereo or mono?
How many vocal mics?
What is your primary concern? FOH or monitors? Both?
One monitor mix
FOH is Mono
3 Vocal Mics
Monitors mainly
I think that does it.
I'd set 18 as fixed. For FOH start with speech and catch the first 3, then change to music low and do 3, then music medium - 6 and then music high for the last 6. Try the same for monitors, but you might have to use more speech filters. I like speech for live also with 5 sec lift times.
If you have a hard time filling the 18 filters, redo and use all music high filters.
Remember, the unit only works in the mode that is selected (live in live and fixed in fixed).
Do you know why the manual seems to advocate using mic channel inserts?
We used the unit for the first time last weekend running the mains in one channel and monitors in the other channel (in the dual mono mode). It worked, I guess, but I wanted to see if I was on the right track.
Thanks again!
themulk
Your 224 is tempting...but I'd better not!!!
themulk
No simple answers. Sorry.
Dennis
It has the ability to send each mixer channel to a \"group\" with it's own fader and L & R outs. I do not know if there's an \"insert\" provision. Looks like I've got some reading to do!
It appears that the insert route is the way to go if at all possible.
Thank you guys for your help!
themulk
Apparently, each channel can be assigned to the main outputs (ST) OR assigned to Group 1-2. Assign all your mics to Group 1-2, then patch the output from Group 1-2 to an empty channel that is assigned to ST. Insert 1 side of the 224 into that channel for house. Then from monitor output, go into the outher side of the 224. I'll assume that you'll set the \"new channel\" at unity and mix the indivual mics from their input channels. You will also mix their monitors from there. ***** DO NOT use the monitor send / aux (whatever) on the \"new channel\".... instant bad feedback. (At least I think that will create an internal loop.)
Gadget, Dennis, does my logic work here? Or do you see another / better way?
Dra, I think your last solution is basically the same as running an AFS channel inline between the mixer and amp EXCEPT you're adding two stages of gain.
Dennis
themulk
Thank you for your response!
themulk
