DRIVERACK PX Setup - FBT Speakers
I have (2) FBTMaxx 4a powered tops & (2)FBTMaxx 9SA Subs. Any reccomendation on what settings to use for those speakers?
Specifications for the 9Sa
System Type: 1 way, Bass Reflex design Dispersion: Omnidirectional
Components: B&C 15â€? LF woofer Protection: FBT ADAP® Protection circuitry
Frequency Response: 40Hz - 125 Hz Inputs: Balanced Neutrik combo jack, XLR, ¼â€?TRS
Suspension Points: N/A Outputs: Balanced Neutrik® XLR link out
Power Output: 900w RMS Enclosure Material: Polypropylene
Sensitivity: 97dB @ 1 watt, 1 meter Dimensions: 19.53�w x 25.51�h x 19.10�d
Maximum SPL: 128dB Net Weight: 64 lbs.
Active Crossover Frequency: 120Hz Shipping Weight: 73 lbs.
System Type: 2 way Dispersion: 90° H x 60° V
Components: B&C 12â€? LF woofer, 1.4â€?HF driver Protection: FBT ADAP® Protection circuitry
Frequency Response: 50Hz – 20kHz Input: Balanced Neutrik combo jack, XLR, ¼â€?TRS
Suspension Points: 4 - M-10 Output: Balanced Neutrik® XLR link out
Power Output: 400w RMS Enclosure Material: Polypropylene
Sensitivity: 98dB @ 1 watt, 1 meter Dimensions: 16.03�w x 24.96�h x 13�d
Maximum SPL: 123dB Net Weight: 35.25 lbs.
Active Crossover Frequency: 1.8 kHz Shipping Weight: 42 lbs.
Ok so what exactly does this mean. 45hz BW18? LR24?
The range that the subs will cover (hz) and the type and slope of the filter points (BW / LR / etc). 45hz to 110hz, then the top cabs will cover 110hz and up.
But I often act as Live sound engineer, and DJ all in the same evening.. so yes, the Driverack is capable of both on the same system...
I tried to set these values in but could not see it when I ran through the Setup, EG and AFS Wizard. Am I suppose to enter these values instaead of doing the wizard? If so...............where exactly do I enter these values...the subharmonic button?
What values? Can you be a little more specific?
Sorry. I copied the wrong one.
3.3 Navigating the High-pass and Bandpass Filter (SETUP) Section
To edit the parameters of the high-pass and bandpass filter used in a selected preset, simply use the following procedure.
From preset mode, press the SETUP button.
Once you have reached the high-pass and bandpass filter module, navigate through the pages of the selected high-pass and bandpass filter module by pressing the \"Next Page\" or \"Prev Page\" buttons successively until arriving at the desired Page.
FrequencySlope presses of the Data wheel will select effect parameters
You have hijacked a 3 year old thread, and look very much like a spammer at this point.
If you really do wish to get help here, go back to the front page and find and read the "READ ME FIRST BEFORE POSTING" thread...
Then come back and start a NEW thread using the instructions in that thread.
Moderator
