Windows 7 compatability?
My back light has failed on my OLD! laptop, so I am looking for new, used, etc laptop. Is Driveware compatable with 7?
I am considering, eliminating by CD/MP3 player system (which needs a $40 "mechanism" that typically won't load in cold weather without removing the cover and tapping the center piece) and going to laptop only. I have always shy'd away, but I also like reducing my footprint at the mix position, so I am cosidering the leap, if the price is right.
Anyone have a trusted source for good used? As usual, I seek great bang for little buck. Of coarse, reliable. (no Vista)
I could go the external monitor route, but that's another thing to carry.
I haven't actually tried it with driveware but I have tried 7 :roll: and it's just a re-packaged vista with a Mac type look interface... in other words they just added a toolbar on the top of the screen that looks very much like Leopard Macware... still has the totally annoying prompt to question every move you make and act as if you'll end up in computer hell if insist on doing it... :twisted: seems a bit faster then vista was but the roadblocks are a pain...I'll put in a note to Mike and get the definitive word though..
I heard that 7 IS actually the completed version of Vista (something about being pushed to release before ready), and works really well.
Hi-Q net has tested all the way through W7/64 bit and works fine...
Band manager has not been tested with vista or windows 7 but field reports indicate that it will indeed run on W7.
Dennis
I showed the "system requirement" post to a local retailer. He said that that was just the requirements for loading 7 on a computer.
My question is, will Driveware work on a computer that has 7 installed? (Driveware compatible with 7)
"If the computer has up to the 32 bit processor, and is running windows 7 Driveware and the 260 should work...
If the computer you are using is running a 64 bit processor and windows 7 you MAY have problems with Driveware and controlling the 260...
That is all the "FACTS " I have
As Dennis and I have also said "unconfirmed" field reports indicate that Driveware works with windows 7...
I guess I don't understand your confusion here... :?
Am I correct that the issue is not running the Driveware, but communicating with the 260?
I hate to be a (insert descriptive slur), but if the laptop I buy can't control my 260, it is money thrown away.
Here is the email:
Gary,
I have used DriveWare on Vista 32 with no problems. Here is the info on DriveWare from engineering.
"If Driveware works on Vista, it should work on Win7. There may be issues with 64 bit on both Vista and Win7."
Best bet would be to take the 260, a known working usb to serial converter and see if they wouldn't install the GUI and see if it runs.. It's easily removed (the GUI) and if they want to make a sale...
The quote I used earlier in the thread was from windows and the system requirements for windows 7.
Ask the Rational Acoustics poster if his computer is 64 bit...he has already said he is able to run "Windows 7 XP Mode" at 32 bit.
Dennis
The 32-bit version can communicate with 32-bit and 16-bit devices. The 64-bit cannot. Other than some games, the 64-bit version does not have much current support (software).
Now I feel better.
I have recently purchased a 260. I have a prolific USB-Serial converter and it works fine on a borrowed Windows XP based laptop using the supplied serial cable. I am unable to use it on my Win7 (64-bit) based laptop. I get an error related to com port. I have tried running in XP compatibility mode but in vain. The port number being used is correct.
At present I have a working cable and converter and a 64 bit windows 7 system with driveware installed but I am unable to connect. Can anyone help?
Check out this old thread http://www.dbxpro.com/Drug/view_thread. ... forumid=15
Thanks for the link. I did see that thread earlier. The solution given there doesn't work since the prolific driver that gets installed on my laptop is the 64 bit version. The files installed are different from the 32 bit drivers and so replacing the file from the link provided (in the above thread) also doesn't work.
Cool
