Newbie needs connection advice.
We have the following equipment:
DriverackPA+
2- Crown xti 4000
1- Crown xti 6000
2- JBL SRX725
2- Peavey SP118
What would be the best way to connect and configure that equipment? I am a newbie with biamping and bridging so the more detail the better. The JBL's have a biamp switch on them. Sorry for the dumb questions, I have been out of sound for quite some time and am trying to catch up.
thanks, Brian
DriverackPA+
2- Crown xti 4000
1- Crown xti 6000
2- JBL SRX725
2- Peavey SP118
thanks, Brian
Run the amps in stereo.. since the mids and lows are 4 ohms each.. that would give you 650 watts for each horn, 600 watts for each midrange 15" and 1050 watts per 18" speaker...the power to the 15's and the 18" is low...but that's what you have...
The outputs of the mixer to the inputs of the DRPA
The HI outs of the DRPA to the inputs of the first XTi 4000
The Mid outputs of the DRPA to the inputs of the second XTi4000
The Low outputs of the DRPA to the inputs of the XTi6000
Set up a 2X4 (fullrange tops and stereo subs) in the wizard...no real need to select the actual components you have since the actual tunings for the tops will be done in the XTi amps... for this you'll need to install System architect in to your computer and then you can automatically download and install the JBL tunings for the SRX725 speakers into the XTi amps...(which is VERY cool!)
The Subs will be crossed in, in the DRPA @ 88.4hz LR48 since your low on power for the subs I'd suggest a HPF of 45hz BW24 or higher...the mids will be crossed in @ 91hz LR48, and Hipassed @1.15khz LR48. The horn is crossed in @ 1.12khz LR48. all the PEQ"s and delays will be handled by the XTi processing.. as well as any limiters you will want to set (especially the one for the tops...
Now that I think about it.. the tunings will have one Xti 4000 running each SRX 725.. one channel will run the lows and the other the highs, and this way one 4 wire Speakon cable will be needed for for each side. One of the Speakon jacks on the back of the XTi 4000 will show that it is the one for bi-amping and will show 1+1- for the low and 2+ 2- for the high outs...
Well.. digest all that and see what you think, we'll be around.. I'm sure you'll have more questions..
Technically you don't need the DRPA .. but it will make your system sound better in the end.. IF you have the measurement mic that is...
thank you VERY much, Brian
I downloaded the software and tunings and will work with that as soon as I get a pair of 12-4 cables put together.
What would you recommend for power/amp with this setup.
On another subject, The lights on the DRPA+ hardly ever move. Just the bottom lights for the channels come on is this normal?
Thanks once again for your help, Brian
A properly tuned and set up bi-amp setup will kick the livin crap out of a passive setup every time and twice on sunday
Did you do a proper gain structure?
viewtopic.php?f=61&t=959
Remember, the DRPA+ is a digital device and does not need to be saturated like an analog device to get that "warm" sound.. and signal to noise is also not the same issue as analog.. if you notice, the ladders on the meter are mostly in 10dB increments...which is one reason you notice that.. just worry more about hitting the clip point of the DRPA+.. THAT is very bad... :roll:
I have to assume that you are asking what you could do to better power this setup? I'd add an XTi2000 for the horns, run the mids with the 6000 and bi-amp the subs with one 4000 each. (if you had the dough, buy another XTi400 and you have redundancy in case of an amp failure.. you can revert to the above suggestions for a 3 amp setup) this would require a jack panel as I said, because it would require 2 amps for the tops, one for the mids and one for the horns.
Note: The Xti series is not known as a great amp for subs...those that have tried all the amps(or have many of the different types) say that there is a BIG difference in the punch and tightness between them and the QSC, IT series Crowns, and most other (read this more expensive) amps.
BTW.. 12awg 4 conductor wire is BIG and heavy..and hard to get into those speakon connectors...14awg is better and acceptable under 50ft. I do run 12AWG (2 conductor) on the sub cables and keep them shorter in length... the very best way is to have a dedicated amp rack on each side (or in my case one that is right next to the stacked together subs and a very short cable run...) and cables that are shorter...
By a jack panel you mean because I have to come out of channel 1 on both the 4000 and the 6000 to +1 &-1 and +2 & -2 on a panel speakon in order to run one 4 conducter cable per side, I have an 8 outlet panel I could wire up. The JBL's are + - 1 on the lows and + - 2 on the highs biamped so I would take +-1 from the 4000 channel1 to +- 2 on the panel speakon and same on the 6000 to +- 1 on the panel speakon. Then wire the 4 conductor cable to speaker accordingly.
I would bridge the 2 XTi 4000 sub amps correct?
I really appreciate the help.
The SRX 725's bi-amped are 1200/2400/4800 @ 4 ohms on the lows and 75/150/300 @ 8 ohms on the highs. The subs are 1200/2400peak @ 8 ohms.
2-xti 4000 bridged mono on the subs, they are 2400w each @ 8 ohms
2-xti 6000 bridged mono on the mids srx 725 that would be 6000w each @ 4 ohms
and a member has a Peavey CS 2000 and CS3000 which are 495w and 650 stereo at 8 ohms respectively which is what the ohms rating is on the highs are.
I'm trying to make use of the xti 4000's we have even though you said they aren't much on the subs.
Honest opinion please.
Thanks, Brian
Go ahead and use the 6000 stereo on the mids and the 4000's bridged mono on the subs.. you will probably not even notice the bass issues as you haven't got anything to compare them to...
So, set up a stereo, stereo, (you will be asked that question twice) 2X6 in the wizard all custom amps and speakers (thats a bi-amp tops and stereo subs)
Use the settings you got from JBL in the amps..
I was under the impression that you had 2, 4000's .. and 1, 6000...
Sounds good thanks!!
We are going with :
2 XTi 4000
2 XTi 6000
1 Peavey CS2000
2 Peavey SP118 subs
2 JBL SRX725 mains
Could you give me the setting/setup for this. I am taking your previous suggestion and bi amping the 725's with the 2 4000's on th mids and the Peavey on the horns. 2 6000's on the subs.
There are no settings in the Crown or DRPA+ for the subs so I would like you opinion as to settings and wether they should be in the DRPA+ or the amps.
Thank you VERY much !! Brian
But hey.. it's really NOT a bother..
Good luck, keep us informed.. I'm off to weddingsville :roll:
Got my patch panel made up and some 4 conductor speaker runs for the 725's.
I couldn't even get close to unity on the master, just way too loud! I had the 4000's and 6000's at about 75% and the Peavey CS2000 at about 50%. That seemed to take the harshess out of the tops and made the sound real nice. The amps kept the 2nd led on and flashed the 3rd every now and then.
Thanks for your help and feel fre to offer your opinions on anything.
Brian
The SP218's are about the best bang for the buck in 2x18" front loaded cabs. They use the same drivers as the QW subs and sound pretty good. Yorkville makes some subs that are a good buy also. I have the LABsubs which are a DIY sub and MAN do they rock! But are a difficult build and very large/heavy.
Glad we could help.
