DRPA+ Connectivity
ampeg610
Does anyone know if when hooking up JBL SRX 725's in bi-amp mode, no subs if you should hook the low or mid output of the DRPA+ to the LOW/MID amp? Right now I have 5 Xti amps on my system running a 2x5 configuration. I run a Xti 1000 on the HIGHS (stereo) of the 725's, a Xti 4000 on the MIDS (stereo) of the 725's and a Xti 4000 on LOWS for my JBL SRX 718's (bridge mono), a Xti 2000 for monitors and another XTI 2000 for extra subs when we run them. We have a few small venues we play and instead of packing in the 718's I would like to try just running the 725's and let the 2x15's pull the low-end work load. Just want to make sure before hand how to connect to the DRPA+. I have already configured the DRPA+ for the 725's and the amps I am using and no sub option, I just dont know what output to use on the DRPA+.
Now, having said that... if you have your rack hard wired and labeled as hi / mid / lo and you want to use the mid outputs as your 725 (only) lows, and want to avoid having to rewire everthing everytime, just make presets that give you what you want. For example, when setting up the 725 (only), set up a bi-amp with subs, but simply adjust the mid x-over / filter to have the HPF that you want for the cab to go lower and don't use the "true" low output on this set-up. Set another preset, also a bi-amp with subs for when you use subs and set the x-over / filters accordingly.
Now in response to Gadget. Is your recommendation based on if I create new presets? Or if I just run off of the low output of the DRPA? And as i stated above to DRA, I don't really understand a lot of the crossover settings like you suggested with the the 3dB down point @ BW18.
We have had the DRPA less than 2 months so I am new to this and the band has given me the responsibility to figure it out because I am the most tech savvy. Any and all help that you guys are giving me is greatly appreciated. I have found that it is usually easier to get advice from experienced users that to try to figure out the users manuals.
UNLESS you are going have a separate amp rack for the smaller gigs...
The settings for the Bi-amp 725's should be in the wizard so setup should be a breeze.
The BW 18 filter is a steep a steep slope meant to protect the woofer from over excrusion...(damage)
The one problem is in stereo you only have 1200 watts per channel...that's 600 watts per 15"... not even the continuous rated output of the speakers.. so if your going to run that low you need more power (sub frequencies require more power) so I would bridge both the 4000's and run one on each cab.... if your going to do that you might want to just make up a preset for the bi-amp tops that would use only the high and low outputs from the DRPA.. simple enough to swap outputs on the DRPA to the amps... Then, if you set up the wires going to the jack panel on the outside of the rack with dual banana jacks, you could just unplug them from the one XTi4000's black and red outputs to the two red outputs on each XTi 4000 amp, and then set the amps to bridged operation. Then you could just let the wizard settings determine the HPF point for the subs.
That is what I would do...
