Home dbx User Forum dbx Archive Threads DriveRack 200 Series 200 Series Software Control
Xover settings problem
jzzenjzzen Posts: 2
edited January 2011 in 200 Series Software Control
I keep getting problem when my pc is connected to 260 unit, and software running.
If i load a preset via unit, i find that the xover settings have all reset to default.
This only happens with laptop (xp) and software running.
Can you explain this?
Also, if i want to load a saved preset from my laptop unto the 260, do i need to import file?
  • GadgetGadget Posts: 4,915
    Not sure what your saying here? Can you be more detailed on the procedure.. use an example maybe?
    The procedure for importing a .dwp file to your 260 from your computer is...
    1. Get the laptop and the 260 communicating through the GUI
    2. locate the .dwp file you wish to import I like to have them in a file on the desktop
    3. on the GUI, right click on the top bar of the GUI and a drop down menu will appear. Select "Import program"
    4. another box will appear and you will need to specify the location of the file (in my case that is Desktop> folder>driverack setups)
    select the file to be imported by highlighting, and click [open]
    This will import the file and then you will need to save that preset to some location on the 260. Select [store] on the GUI control surface and from the drop down box name the preset, select the preset location and select [yes] replace an existing program. This will overwrite the program stored in that user location, but it will still be in the factory default if it is a factory preset.
    Done...
  • jzzenjzzen Posts: 2
    Gadget thanx for the ultra fast response.
    I will write down a detailed example, when i get a chance to simulate issue.
