Advice for DRPA+ for New Setup
I'm new to livesound. Since my speakers are not selectable in the wizard, I’m looking for advice on Xover Frequency settings, filter type, slopes, Delay, and PEQ. I have a DriveRack PA+ and need a 2x4 Program. Please excuse my inexperience and I would really appreciate your help. Thank you in advance for any help!
Mixer: Soundcraft LX7-II24
2 x Main Speakers: Bob Audio CS225 2-Way
http://www.bob-audio.com/eng/product/CS225.asp
Frequency Response: 43 Hz - 18 kHz (±3 dB)
Sensitivity HF 103dB , SPL(1W @ 1m)
Nominal Impedance 4 ohms
Power Rating LF 1000 watts (rms) ,
2000 watts (program) ,
4000 watts (peak)
Maximum SPL 130dB
Nominal Dispersion 90°horizontal
60°vertical
Crossover Frequency 1.5kHz
2 x Subwoofers: Bob Audio BS1000
http://www.bob-audio.com/eng/product/BS1000.asp
Frequency Response 35 Hz - 350 Hz @ -10 dB
Sensitivity 104 dB SPL (1W @ 1m)
Nominal Impedance 2 x 8 ohms
Power Rating 1400 watts (rms) ,
2800 watts (program) ,
5600 watts (peak)
Maximum SPL 135 dB
Crossover Frequency 100 Hz
Power Amplifier for 2 x Main Speakers: SoundBarrier PCS5000
http://www.soundbarrier.com/professiona ... spx?id=172
Specs: 2Ω Dual (per channel): 2400W
4Ω Dual (per channel): 1900W
8Ω Dual (per channel): 1200W
4Ω (Bridge / Mono): 4400W
8Ω (Bridge / Mono): 3000W
Frequency Response: ±0.25dB from 15Hz-25KHz
Signal to Noise Ratio: >100dB
Damping Factor: >400:1
Total Harmonic Distortion: <0.03%
Selectable Input Sensitivity: 0.77V-1.0V-1.44V
Power Amplifier for 2 x Subwoofers: SoundBarrier PCS6000
http://www.soundbarrier.com/professiona ... spx?id=173
Specs: 2Ω Dual (per channel): 2800W
4Ω Dual (per channel): 2100W
8Ω Dual (per channel): 1400W
4Ω (Bridge / Mono): 5600W
8Ω (Bridge / Mono): 3100W
Thank you,
4000 watts (peak)
Maximum SPL 130dB
60°vertical
5600 watts (peak)
Maximum SPL 135 dB
Thank you,
1. use the 100hz LPF LR24 for the subs, and set a 40-47.5 hz HPF using BW18 filter
2. use 100hz HPF LR24 for the tops...
Eq... no idea... no one is gonna have those speakers... I suggest an auto eq pass outdoors, away from all reflective surfaces with flat response and medium precision following the edicts here...
viewtopic.php?f=61&t=959
and the FAQ's here:
viewforum.php?f=60
