286s as processor only?
I'm thinking about getting a different stand-alone mic pre for my VO work, but I like the simplicity of the processors on the 286.
Is there a way to use the 286's processing section only with/thru another pre? I've never tried anything like this before, and could use some advice. I've read a bit about the inserts on each, but am still a bit hazy and hesitant on this.
Mark
Mark
You'll need to be more specific than this...
I thought you were 'unhappy' with the setup I was suggesting, but now that you wrote that, I think you were saying that you're not real happy with the 286 in general, right?
For my VO work, I'm used to the expander/gate on the 286 to get rid of as much ambient noise as I can, then do any more clean-up in my DAW.
I can't afford any more gear beyond the pre I'm getting and thought maybe I could find a way to make use of this part of the 286 coupled with my new pre.
I guess I'll take a much closer look at the book...
The Presonus mixer platform has opened up a whole new world to me... I have a 16:4:2 studio live, and I can mix remotely with a laptop, I can also control all my monitor mixes from an Iphone! I can record, multitrack, all my shows, and even have a mixdown pair recorded as well..I can even route tracks to the DAW in real time and send them back to the mixer for live sound using all the DAW plugins...
Mind blowing stuff in this price range.
If you know anyone with any ideas on the 286 thing, please send them my way!
Mark
Some level discrepancy might be there but hopefully there is enough gain to be able to make it all work...The impedance differential my require you to use the line level outs of the focusrite... but I'd try the XLR out first.
Can't hurt to try, it's all line level after all...
I'm wondering if you ever got an answer to this question about using just the processing on the DBXs and bypassing the preamp on it and instead using the preamp on your ISA One. I see one post with a (to me at least -- pins/positive/cold etc) very confusing answer. I'm terrible to tech stuff. Did you ever figure out the right way to hook it all up? I have the same system -- I'm using Logic (DAW) and just bought an ISA One, a Neumann TLM 103 and a MOTU 828Mk3 and want to only use the gate of the DBX (I'm a voice over guy). Any solution would be great.
Best,
Sam
Although I have a different pre now, I'll still patch thru my 286 when I want to gate pre-DAW.
Yes, Gadget is right in that one can have a custom cable configured, but I'm going to give you the simple fix from one VO guy to another! And yes, this will bypass the preamp section of the 286...
If you don't already have one, get a 1-2 ft.(the shorter the better)patch cable with a female XLR plug on one end, and a 1/4" TRS plug on the other & another short patch w/TRS on both ends.
Here's the chain: (Power off please)
Mic>ISAONE-ISAONE Output>DBX Insert(with your new XLR/TRS cable)-DBX Output>Interface or Computer (with other TRS cable). Now, THIS IS IMPORTANT! Pull the 1/4" DBX INSERT PLUG OUT ONE CLICK. (You'll feel it).
Turn down input and outputs and power-up! Increase sets to taste. I Kept the DBX Output Gain at 12:00 (0dB).
This should work.
Good Luck,
Mark
Sam.
Please do let me know if that setup works for you!
All the Best,
Mark
http://www.youtube.com/watch?v=cVedzPUwwSU
http://www.youtube.com/watch?v=-YYL0njoeNw
http://www.youtube.com/watch?v=R71JOxQdgg0
