help with setup and tunning
Hello all,
I have 166xl hookup to main out from mackie 1604 vlz pro mixer. I just bought DBX 260. My question is how to hookup the 260 to the system? And what manufacture setup should i select to make it sound good?
My system setup now is this:
mackie 1604 is my mixer-aux 1 and 2 send and return to elesis quadraverb effect. main insert go to dbx 166xl. main out go to bose controller and the go to QSC amp and to bose 802 speakers. and also from bose controller, the low frequency out go to Harbinger HP118S Powered Subwoofer.
How to set up dbx 260 to sound the best is live application? Should i insert the 260 between the main out and bose controller? What eq do you suggest for my system? or should I just use the automatic eq.
Thank you
Thank you
our main usage are for solo, choir singing at church. we have four musicians. two guitarist, 1 drummer, 1 keyboard. we also want to use it for dj/karaoke set up at parish center.
thank you
P., have you done the 260 tutorial in the Training section above? If not, do. It will really help you with some answers, and allow you to ask more direct questions. Will you be using the Driveware to control the 260 by a computer? (You should.)
