intermediate setup question drpa+ over xti amps
I've been doing sound for several years now, but I'm getting more into the digital world with it.
I heard something from the "harman guy" at sweetwater recently that made me start thinking about setting up a little different. The suggestion was that I ought to move as much of the "processing" to the amps as possible, and mainly use the drpa+ for balancing and master eq-ing.
Here's what I'm working with:
2 STX812m as tops
2 SRX718 as subs
drpa+
2 xti4002 amps
This is a live sound (band) setup, and for the venues, I could care less about stereo, so to get the most power from the amps, I am running the tops daisy chained off of one amp in bridged mono (3200 w total output), and the subs off the other amp in the same way.
What are your opinions about using the amp dsp instead of the drpa+ for crossover, limiter, eq?
I do have bandmanager2 installed, and have played around a little, but don't really see much extra capability compared to the front panel.
2 STX812m as tops
2 SRX718 as subs
drpa+
2 xti4002 amps
Let us know how this work out for you, as others can learn from your experience.
Through bandmanager2, there is an output attenuator, but I I have not found any documentation of how it works.
As for PEQs, I have never even used them in either the amps or in the drpa+. Should I be? What benefit would I have? The freq response curves for the speakers in this rig are quite flat to begin with, and after auto eqing with high precision on the drpa+, my external rta software shows good results.
I'll assume that your Auto EQ sessions have been in a free air environment. The PEQ's are just to "perfect" the 2-3db dips and peaks that show up. If you don't have them... great news for you. If you have adjacent GEQ frequencies in a given room giving you feedback problem. Trade them off to a single PEQ filter. The result will be more pleasing and less audible.
WHat do you think?
ALSO, do you know where I can find more documentation on the output attenuator for the xti2 amps?
Auto-Eq passes are quicker and less invasive if the cabs have a "flattest" starting point.
