Cant get passed Step 23A on DR PA Set up (2-way)
Hi,
I'm set up running Stereo....2 1-18 subs and 2 SF-15 JBLS (mains)....I'm running on Preset 2 (Stereo 2-way)....whenever i get to step 23A, the pink noise stays on, but never gives me that prompt "Set to Performance Level", so i can go one to 24A where the Auto EQ takes over.....
Notes: THis last time i ran thru the process, it was much louder on the right side than the left (mic is split in the middle)....the overall volume of the pink noise however, is not that loud; far from "performance level"....the LED's are lighting up like its doing its job but i cant get past this step....it stays here forever....please help, really discouraged right now....thanks! Mark
w/DRPA+....It has worked, but usually does not. I measure 14 volts on pins 2 & 3 from DRPA+, cord is good, dbx rta mic sounds weak when plugged into board to test.
dbx tech says selecting custom speakers in setup is cause, and to skip balance.
Auto eq has issues with level too. Shouting into mic helps to trick unit sometimes.
I am taking mic to store for comparison with new mic.
