4 way mono
Hi,
I would like to have some suggestions on setting my Dr 260 crossover frequencies. I have already configured it to four way mono. These are speakers I intend to use:
High----Jbl 2446h---
high mid---Jbl 2206h
low mid----Peavey 1505 dt
(The top boxes are font loaded with the high, high mid and the low mid speakers.)
Lows----EVX 18b---super scoop box
The horn should cross maybe around 750hz.
The 12" should cross no lower than 125 - 200hz.
Do you want the fundamental kick sound (80hz) to be in the sub or the 15"
While I tend to roll my own, I pay attention to what the manufacturer does and the lowest I have seen JBL xo that style of horn is 933Hz but 99% of the time I see a 1.1kHz to 1.3kHz crossover point. I hesitate to recommend a 900something xo point because it is easier to overdrive the horn at lower frequencies.
