Driverack PA2 won't accept firmware update...
Ok, a strange issue here. I have 3 driverack pa2 units. All 3 connect to home network and I can connect to them with my laptop using the control app just released. I was able to update the firmware in 2 of the units with no problem at all. Updated from 1.1.2 to 1.1.9. The last one will not update. What happens is the laptop downloads the update, then it starts to upload to device (for about 1/2 second) then the driverack reboots itself, killing the connection... Since the firmware never had a chance to upload to the rack, it simply boots up normally with the original firmware. I have tried rebooting the laptop, cycling power on the drive rack, both... All to no avail. I am using same Lan cable (just moving it from driverack to driverack). It worked on first unit no problem. Did not work on second. Worked fine on 3rd. I then tried #2again,and same result... Puzzled.. Any ideas or work - around?
DRA,
Yeah, called tech support yesterday... they suggested trying a hard factory reset (holding down store button while powering up)... and if that didn't work they recommended returning the unit...
The hard reset did not fix the problem, so I am returning this unit today... (bought it from Guitar Center... they've been good to work with so far...)
