driverack p2
I just got my drpa2 yesterday and I was wondering how to customize outputs. Is it possible to assign the outputs like this. Out1) left - right stereo full range (ev elx215) out2 left right stereo full range (ev sx500+) and finally out3 ev sb180 stereo subs. Then I would apply ranges and hp lp settings. If it's not possible then I need to return this asap. Seems super easy in the "other guys" rack.
Extend the high x-over down to say 100hz (or wherever you want).
Extend the mid x-over up and down to match the high band.
Set the sub x-over accordingly.
The one potential problem I see it that when the auto eq and leveling is done, there may be some confusion.
You may have to not use the wizard in these steps
I was curious to hear your comments about the Auto EQ using the parametric eqs. I always thought the processing power would never be enough to accomplish that... but here it is.
