How do I connect a 4 speaker center cluster, 2 models?
Here is my setup.
Behringer X32 Board
2 Foh Br15 Yamaha speakers
2 Foh JBL MP215 speakers
2 Mackie 1801 Powered Subs.
The two JBL's are hung in a center cluster
The two BR15's sit one on each of the outsides of the JBL's.
The JBL's are on one bridged crown amp CE2000 and run in parallel
The BR15s are on one Peavy CS800 bridged amp run in parallel.
What is the best way to configure the PA+ so that each of the speakers can be EQ'd correctly and what are the correct crossover points for each as well? My head is hurting trying to figure it all out. Just need it all mono as well. Thank you!
Behringer X32 Board
X-over settings:
High - 100hz LR24 - out
Mid - 100hz LR24 - out
Low - 35hz BW18 - 100hz LR24
PEQs available:
High - 3 (assign the speaker that needs the most correction here)
Mid - 2
Low - 2
Example: Setup as Mono or Dual Mono or Stereo or Stereo Linked, etc.
Personally I would set up as mono. If you were more experienced with the DRPA, you might try stereo. The benefit is that you can have a GEQ for each set of speakers, but with that... more probability that you adjust the wrong GEQ. You would have to send 2 mono signals from the mixer to the left and right inputs (easy, just pan all channels to center). To be able to control the top cab sets separately (gain, PEQ, limiters (AFS is always linked, so if you have more feed back issues from on set vs the other be sure to turn off the other set when setting the AFS) AND have separate GEQ, set 1 goes on left high, set two goes on mid right, subs should go on the side with your primaries.
