will Behringer pmp4000 work with the Driverack pa2
I have a small electronic drum room with a pmp4000 powered mixer. I am running 2 active speakers from the main outs on the top of the board. Then I am using 2 passive speakers from behind the board. I also have a powered monitor. I have been hearing conflicting stories if the PA2 will work with my setup. I do not want to loose control over my speakers or monitor as well from the board. I would like to know first if this will work with my system? then if any ideas for the right connections. Thank you.
You need 2cables like this, BUT the male & female connectors are reversed. The ring need to be Male and the Tip needs to be Female.
The next step is to configure the PA2 to allow the monitor to be on one channel and the 2 sets of main on the other channel. For example,
monitor out to left in
Main out to right in
monitor out high left
Main (set one) out mid right
Main (set two) out low right
This gives you 3 custom x/over filters, 3 custom PEQ setting for each, 3 distinct limiters.
The mains will share a GEQ and the monitor will have its own GEQ.
The feedback section will be shared for all.
"http://www.audiopile.net/YIN-MF
You need 2cables like this, BUT the male & female connectors are reversed. The ring need to be Male and the Tip needs to be Female."
