Help with configuring Lin6 Stagesource speakers
Hi
So I finally got the Venu360 unit however I am unable to setup the Xover frequencies for my speakers correctly. Can anyone assist with the settings I should put for customizing the speakers for the Mains (Line6 StageSource L3t Powered speakers) and Subwoofer (Line6 StageSource L3s Powered Subwoofer) in the Stereo Speaker with Mono sub configuration. I know these may not be the best speakers for our House of Worship, but we need to have them for atleast another year n half before we upgrade to something else.
Please guys, I would really appreciate if anyone can tell me the configuration values for how they should be setup for Xover and power amp settings and how they need to be configured.
Thanks guys
FOH
Presonus Studio Live 24AI mixer
Line6 StageSource L3t for FoH
Line6 StageSource L3s Subwoofer
Guitar
Line6 Helix
Les Paul Studio Pro 2014
Monitors
Digital Audio Labs Live Mix AD-24 Personal mixing system
Sure SE 535 IEM
Sennheiser ew300 G3 Wireles IEM
Thanks guys
FOH
Guitar
Line6 Helix
Monitors
Sure SE 535 IEM
Appreciate the effort.
Have you downloaded the ap?
Have you watched the tutorials available?
You can play around in virtual mode, and learn a lot.
Go through the Wizard system set-up.
I assume that you are not using the "link system".
Set up the 360 with subs as "Mono x2" config.
If you have problems getting through the set-up process, let me know.
I recommended x-over setting as follows:
mains 120hz LR24
Subs 45hz BW18 - 120hz LR24
Set the x-over switch on the sub to "OFF"
If you have questions, let me know.
Here is some info that i gathered from the manufacturer (Line6) and their distributor here
Hi
So here is what I gathered from the manufacturer (Line6) and supplier. Please help me in setting the values for the custom speakers.
"The L6L3T and L6L3S are powered cabinets with active DSP. I would put NO extra processing on the cabinets, as they do not need it. Do not use the Crossover, Limiters, or Parametric EQ on the DBX as they are already built into the cabinets. The only thing I’d use the DBX for would be Graphic E.Q (to tune the speaker system to the room) and the feedback suppressor to get rid of unwanted problematic frequencies.
I recommend this exact procedure with all Yorkville powered cabinets when they are used with our ART SMS226, and VTC DLMS4080 processors. Send the outputs of the mixer to the inputs of the DBX, and take the “High/Mid� out into the L3T and Sub out into the L3S and run two full range signals (let the DSP, crossovers and limiters do all the work as they are intended to do). They may want to add a bit of subharmonic synth if desired. Not too much, as those speakers are only dual 12’s."
Here are the specs of the speaker as well:
L6L3T
Frequency Range (-10db) 40Hz to 19kHz
(+3db) 47Hz to 18kHz
The L3t is a tri amp loudspeaker
LF1 Low pass is at 250Hz
LF2 to HF Crossover is anywhere from 2.2kHz to 7.0kHz (Depends on speaker mode)
Maximum Gain Input is +25dBu (This is Gain at minimum and 20 dB pad on.
Gain range is Infinity to +57dB
Onset Limiting Occurs at +7dBu (Master level control at Center)
-5dBu occurs at Master Level at Maximum.
L6L3S
Freq. Range (-10dB) 34Hz to 2.8kHz
+3dB 38Hz to 910Hz
Max Input Level +20dBu
Limiting +11 dBu (Master at Center)
-1 dBu (Master at Max.)
Please let me know how to configure the speaker from these values provided by the Speaker manufacturer and distributor. Additionally, would the Venu360 be an over-kill for my current need and if so, which would the right Drive Rack to use for our current speaker. Would i need to turn off the Crossover, Limiters, and Parametric EQ on the Venu 360 and use it only for GEQ, AFS and subharmonic synth?
Kindly let me know your thoughts, so I can make a decision and set it up for this weekend.
If the Sub allows for stereo inputs to pass through to the R&L tops, I agree with the manufacturer. No guess work on the filter types and frequencies.
As far as using the GEQ, You can use it to find the problem areas and then transfer the info to the PEQ. PEQ's affect phase much less than GEQ's. Sub-synth? I wouldn't use much, if any. Are you going to control the monitors with it?
Yes I plan to use a little sub harmonic synth, as required. Our congregational worship session typical requires a lot more bottom end and I believe a little sub harmonic synth will assist in this.
Yes I still dont know the values to enter in the wizard while running the Wizard from my tab/pc (- HP Frequency, - LP Frequency, - Gain, - Phase, - Polarity, - HP Slop Type, - LP Slope Type, - Parametric EQ settings) to enter for the speakers and subs in the Venu360. Here are the details I gathered regarding the speakers and subs:
L6L3T
L6L3S
+3dB 38Hz to 910Hz
