which driverack for me ?
OK I've decided it's time to upgrade . I am a small bar band /dj kj sound guy when I run for bands it's the typical mains ,subs and 2 monitor sends .When I dj and karaoke its 2 mains and a hot spot monitor Now keeping in mind I have a small budget which driverack would you recommend ?
If you mix true stereo and a single monitor mix (but going to 2 monitor positions), you need the Venu360. 3 separate sound source inputs that must remain separate?
If mono FOH and a single monitor mix, you might get by with the PA2, but there are limitations in that some modules cannot be adjusted / used separately, like the AFS is combined so that what feedback frequency is pulled out in monitors, is also pulled out in the mains. You would be wiser to purchase a used Driverack 260 for this 2 input scenario.
In the FAQ section you will find this and many more useful stuff. viewtopic.php?f=60&t=2228
There will be some difference, potentially, from the PA2, but the principles apply.
If you need clarification, feel free to ask.
PS - Even with the fancy tablet control, if I had a monitor mix, I would want it completely isolated from the mains input in all modules. A used 260 would be my choice. It still has laptop control and much more versatile than any in the PA series.
