Driverack PA2 Auto EQ With One Channel (Mono) Setup
I have found older threads discussing the issue with Auto E using only one (mono) speaker on one channel and would like to know if this has been resolved as the latest thread I found was dated 2014 in which it was deemed necessary to use a 'Y' cable to simulate the second channel connection.
Also, with the one channel only setup should I do more than one mic placement and if more than one is desirable what distances/placement is best to use.
I will be using one Bose L1m2/B2 full range active speaker array in this setup (mono out of one channel).
Thanks for your reply, I have read the manual but unfortunately you didn't read my post, I am only using 1 speaker in a mono setup.
Well, if you are only using 1 speaker for performance, you still would be best to get multiple samples around the room. They all just need to be within the pattern of the speaker.
Never mind, at least you tried.
I can resolve the single speaker issue using a Splitter cable reducing the two outputs into one line but what I'm really not sure about is how far away to place the RTA mic, is it advantageous to take more than one reading and if so where should I place the mic for subsequent readings, somewhere along the direct in front axis or slightly off axis, does it really matter?
Mic @ 40' - 0 degrees
Mic @ 25' - 45 degrees left
Mic @ 55' - 45 degrees right
Mic @ 75' - 45 degrees left or right
More than 45 degrees if appropriate, but you get the idea.
