Home dbx User Forum dbx General Discussion
Is anyone using the VENU360 in studio
I have maxed-out my footprint with professionally treated bass traps, etc and the room is decent overall. I currently use a software-based program (within my DAW) to tune the space the rest of the way- works well. I would however like to hear the other audio sources thru the same "tuned" treatment. Is anyone using a VENU360 or similar unit for this purpose. Thanks in advance!!
  • EEldeEElde Posts: 1,376
    I have talked to several customers who use the PA2 and Venu360 to tune and control their monitors in the studio yes. Feedback has been positive overall
  • SRosetteSRosette Posts: 3
    Thanks so much for your answer. Is there something about either one which would commend it over the other?
    VENU360 ordered. Wish me luck!!
    The Venu360 has the ability to run mono separate paths and a third input for more Input routing ability and to be able to aux feed subs or monitor paths yes. Also you get a lot more input/output routing where the PA2 is pretty much a Stereo 3 Way Crossover.
    The Venu360 offers more between the two. Also whereas the PA2 runs one AutoEQ for all outputs, the Venu360 can run an AutoEQ for each output.
  • rdoerschrdoersch Posts: 6
    The venu360 also has AES inputs also if you have the AES outputs to drive them so you don't have to do the extra a2d, d2a.
    That's a good point as well!
