Home dbx User Forum dbx Archive Threads DriveRack PA2
Input Mixer? Mono config?
I'm going to buy another driverack, it would be a venu360 but $$$ is an issue, I'm wondering if a PA2 will do what I need.
A couple of questions:
  • After reading the user manual, it appears as though the PA2 doesn't have an input mixer; is that correct?
  • If the PA2 is configured for mono and both inputs are used, will the inputs be summed, or will one input be ignored?
  • EEldeEElde Posts: 1,376
    edited May 2020
    Make sure you post in the newer section for dbx questions, and not the archives, there are not monitored very actively any longer.
    To answer your questions though
    That is correct, no input mixer.
    They will not be summed no, the Left input becomes Mono in.
  • Thank you, that helps. My new purchase will have to be a Venu360... might just be a little while longer before I get there.
    Also thanks for pointing out that I posted in the archives, it wasn't intentional.
